Ir para o conteúdo principal
Asus Chromebook C300M Mousepad Replacement
O que você precisa
  1. Asus Chromebook C300M Mousepad Replacement, Mousepad: passo 1, imagem 1 %32 Asus Chromebook C300M Mousepad Replacement, Mousepad: passo 1, imagem 2 %32
    • Flip the Chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M Mousepad Replacement: passo 2, imagem 1 %32
    • Separate the plastic case from the keyboard at the seam by using a plastic opening tool.
  3. Asus Chromebook C300M Mousepad Replacement: passo 3, imagem 1 %32 Asus Chromebook C300M Mousepad Replacement: passo 3, imagem 2 %32 Asus Chromebook C300M Mousepad Replacement: passo 3, imagem 3 %32
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using spudger.
  4. Asus Chromebook C300M Mousepad Replacement: passo 4, imagem 1 %32 Asus Chromebook C300M Mousepad Replacement: passo 4, imagem 2 %32 Asus Chromebook C300M Mousepad Replacement: passo 4, imagem 3 %32
    • Remove the keyboard and flip it onto its front. You should see the back of the mousepad.
    • Lift the foil strips to reveal two hidden screws. Then remove all four 2mm screws from the top of the trackpad with the Phillips #1 screwdriver.
    • Remove the mousepad by sliding it upward.
Conclusão
Uma outra pessoa concluiu este guia.
Rachel Cadle
Membro desde: 04/02/19
259 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G2, Harley Spring 2019 Membro de IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 340
