Ir para o conteúdo principal
Asus Chromebook C202SA-YS02 Touch Pad Replacement
O que você precisa
  1. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Palm Rest: passo 1, imagem 1 %32
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Touch Pad Replacement: passo 2, imagem 1 %32 Asus Chromebook C202SA-YS02 Touch Pad Replacement: passo 2, imagem 2 %32
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Touch Pad Replacement: passo 3, imagem 1 %32
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Touch Pad: passo 4, imagem 1 %32
    • Gently peel off gold tape.
  5. Asus Chromebook C202SA-YS02 Touch Pad Replacement: passo 5, imagem 1 %32
    • Remove the three Phillips #1 3.5 mm screws located on the under-side of the palm rest.
    • You can now pop out the touch pad.
Conclusão
Beau Hansen
Membro desde: 09/28/17
845 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,315
