Ir para o conteúdo principal
Asus Chromebook C202SA-YS02 Screen Replacement
O que você precisa
  1. Asus Chromebook C202SA-YS02 Screen Replacement, Bezel: passo 1, imagem 1 %32
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Screen Replacement: passo 2, imagem 1 %32
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Screen Replacement: passo 3, imagem 1 %32
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Screen Replacement, Screen: passo 4, imagem 1 %32 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: passo 4, imagem 2 %32 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: passo 4, imagem 3 %32
    • Unscrew and remove the four screws holding the screen in place.
  5. Asus Chromebook C202SA-YS02 Screen Replacement: passo 5, imagem 1 %32
    • Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
Conclusão
4 outras pessoas executaram este guia.
Beau Hansen
Membro desde: 09/28/17
845 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 70
Duração total: 3,349
