Introdução
Removal of the palm rest is a preliminary step in many replacement guides for the Asus Chromebook C202SA-YS02. Also, if your keyboard is damaged and needs replaced, it might be easiest to replace the entire palm rest.
O que você precisa
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
Quase terminado!
Conclusão
