Ir para o conteúdo principal
Asus Chromebook C202SA-YS02 Palm Rest Replacement
O que você precisa
  1. Asus Chromebook C202SA-YS02 Palm Rest Replacement, Palm Rest: passo 1, imagem 1 %32
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Palm Rest Replacement: passo 2, imagem 1 %32 Asus Chromebook C202SA-YS02 Palm Rest Replacement: passo 2, imagem 2 %32
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Palm Rest Replacement: passo 3, imagem 1 %32
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
Conclusão
Beau Hansen
Membro desde: 09/28/17
845 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 672
