Introdução
Sometimes your camera can become damaged and need replacing. Note: if your device locates the camera, you may not actually need to replace the hardware. If you do, though, this guide is for you!
O que você precisa
Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
Using the spudger, disconnect the cable from the camera. The camera will then pop out.
