Ir para o conteúdo principal
Asus Chromebook C202 Motherboard Replacement
O que você precisa
  1. Asus Chromebook C202 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Asus Chromebook C202 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Phillips #1 Screwdriver
    $5.49
    Comprar
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Motherboard Replacement: passo 2, imagem 1 %32
    iFixit Opening Tool
    $1.99
    Comprar
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Motherboard Replacement: passo 3, imagem 1 %32
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Motherboard Replacement, Wireless Card: passo 4, imagem 1 %32
    • Remove the black and white wires from the wireless card.
  5. Asus Chromebook C202 Motherboard Replacement: passo 5, imagem 1 %32
    • Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
  6. Asus Chromebook C202 Motherboard Replacement: passo 6, imagem 1 %32
    • Gently pull the wireless card away from the motherboard.
  7. Asus Chromebook C202 Motherboard Replacement, Battery: passo 7, imagem 1 %32 Asus Chromebook C202 Motherboard Replacement, Battery: passo 7, imagem 2 %32 Asus Chromebook C202 Motherboard Replacement, Battery: passo 7, imagem 3 %32
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  8. Asus Chromebook C202 Motherboard Replacement: passo 8, imagem 1 %32 Asus Chromebook C202 Motherboard Replacement: passo 8, imagem 2 %32 Asus Chromebook C202 Motherboard Replacement: passo 8, imagem 3 %32
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  9. Asus Chromebook C202 Motherboard Replacement: passo 9, imagem 1 %32 Asus Chromebook C202 Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  10. Asus Chromebook C202 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the battery from the Chromebook.
  11. Asus Chromebook C202 Motherboard Replacement, Motherboard: passo 11, imagem 1 %32
    • Unscrew one 3 mm Phillips #1 screw.
    • Unscrew one 2.5 mm Phillips #1 screw.
    • Unscrew four 4 mm Phillips #1 screws.
  12. Asus Chromebook C202 Motherboard Replacement: passo 12, imagem 1 %32 Asus Chromebook C202 Motherboard Replacement: passo 12, imagem 2 %32
    • Disconnect the wires that connect the motherboard to the speakers.
    • Disconnect the motherboard from the display.
  13. Asus Chromebook C202 Motherboard Replacement: passo 13, imagem 1 %32
    • Lift the motherboard up and out of the chassis.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 3-1, Passmore Fall 2016 Membro de USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 44
Duração total: 2,487
