Ir para o conteúdo principal
Asus Chromebook C202 Keyboard Replacement
O que você precisa
  1. Asus Chromebook C202 Keyboard Replacement, Palm Rest: passo 1, imagem 1 %32
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202 Keyboard Replacement: passo 2, imagem 1 %32 Asus Chromebook C202 Keyboard Replacement: passo 2, imagem 2 %32
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202 Keyboard Replacement: passo 3, imagem 1 %32
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Once the cables are disconnected, remove the keyboard from the back panel.
    • Now that the keyboard is disconnected, you can replace it with a new one.
Conclusão
Um comentário
Is it easy if your replacement keyboard doesn't include the frame? How does the frame attach to the keyboard?
Alexander Pruss - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 50
Duração total: 1,923
