Ir para o conteúdo principal
Asus Chromebook C202 Battery Replacement
O que você precisa
  1. Asus Chromebook C202 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Asus Chromebook C202 Battery Replacement, Back Panel: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Phillips #1 Screwdriver
    $5.49
    Comprar
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Battery Replacement: passo 2, imagem 1 %32
    iFixit Opening Tool
    $1.99
    Comprar
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Battery Replacement: passo 3, imagem 1 %32
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Battery Replacement, Battery: passo 4, imagem 1 %32 Asus Chromebook C202 Battery Replacement, Battery: passo 4, imagem 2 %32 Asus Chromebook C202 Battery Replacement, Battery: passo 4, imagem 3 %32
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  5. Asus Chromebook C202 Battery Replacement: passo 5, imagem 1 %32 Asus Chromebook C202 Battery Replacement: passo 5, imagem 2 %32 Asus Chromebook C202 Battery Replacement: passo 5, imagem 3 %32
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  6. Asus Chromebook C202 Battery Replacement: passo 6, imagem 1 %32 Asus Chromebook C202 Battery Replacement: passo 6, imagem 2 %32
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  7. Asus Chromebook C202 Battery Replacement: passo 7, imagem 1 %32
    • Remove the battery from the Chromebook.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 3-1, Passmore Fall 2016 Membro de USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
Membros da 4
Autoria de 16 guias
2 comentários
Worked great. Was able to order a replacement battery for my daughter’s two year old Chromebook. $39.99 and relatively easy to swap out.
Ben McCormack - Responder
You did such a great job writing this documentation. I would not consider myself to be good at taking apart things and putting them back together again but your amazing pictures showing each step of the process gave me the confidence to try it myself! It was perfect and exactly what I needed to get this switched out!
peasem7 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 64
Duração total: 4,715
