Ir para o conteúdo principal
Asus Chromebook C201PA-DS02-LG Screen Replacement
O que você precisa
  1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: passo 1, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: passo 1, imagem 3 %32
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 2, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 3, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 4, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 4, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 4, imagem 3 %32
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 5, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 5, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: passo 6, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: passo 6, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: passo 6, imagem 3 %32
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: passo 7, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: passo 7, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: passo 7, imagem 3 %32
    • Unscrew the 4mm screws with a Phillips #0 screwdriver by rotating the screwdriver counterclockwise.
    • There is a screw that is hidden under the black tarped connection that connects the screen to the motherboard.
  8. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 8, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 8, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the tarp material straight up off the external output using tweezers. It is simply taped on.
  9. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 9, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 9, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 9, imagem 3 %32
    • Use a pair of tweezers to grip the tarped connector and lift vertically up. It may help to do this on each side of the attachment, rather than in one pull.
    • Lifting the tarped connector straight up may feel like you are breaking it, but this is normal.
  10. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 10, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 10, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 10, imagem 3 %32
    • Pop these two connections off by using tweezers to lift straight up.
  11. Asus Chromebook C201PA-DS02-LG Screen Replacement: passo 11, imagem 1 %32
    • Lift the screen up to fully remove.
Conclusão
Brittany M Won
Membro desde: 04/18/18
577 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G4, Livingston Spring 2018 Membro de Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 253
