Ir para o conteúdo principal
Asus Chromebook C201PA-DS02-LG Battery Replacement
O que você precisa
  1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: passo 1, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: passo 1, imagem 3 %32
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 2, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 3, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 4, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 4, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 4, imagem 3 %32
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 5, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 5, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: passo 6, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: passo 6, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: passo 6, imagem 3 %32
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: passo 7, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: passo 7, imagem 2 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: passo 7, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  8. Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 8, imagem 1 %32 Asus Chromebook C201PA-DS02-LG Battery Replacement: passo 8, imagem 2 %32
    • Use the plastic opening tool to lift up the battery and remove it.
    • Do not dispose of the battery in normal waste. The chemicals inside are toxic. Find out where to dispose of properly in your neighborhood.
Conclusão
Ashley Humpal
Membro desde: 04/18/18
185 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S17-G4, Livingston Spring 2018 Membro de Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 356
