Ir para o conteúdo principal
Asus Chromebook C201 Palm Rest Assembly Replacement
O que você precisa
  1. Asus Chromebook C201 Palm Rest Assembly Replacement, Palm Rest Assembly: passo 1, imagem 1 %32
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 2, imagem 1 %32
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 3, imagem 1 %32
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 4, imagem 1 %32
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 5, imagem 1 %32 Asus Chromebook C201 Palm Rest Assembly Replacement: passo 5, imagem 2 %32
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 6, imagem 1 %32 Asus Chromebook C201 Palm Rest Assembly Replacement: passo 6, imagem 2 %32 Asus Chromebook C201 Palm Rest Assembly Replacement: passo 6, imagem 3 %32
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 7, imagem 1 %32 Asus Chromebook C201 Palm Rest Assembly Replacement: passo 7, imagem 2 %32
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Palm Rest Assembly Replacement: passo 8, imagem 1 %32
    • Remove the keyboard cover and safely place it somewhere face down.
Conclusão
Robert Lawson
Membro desde: 02/09/16
841 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-51, Cagle Spring 2016 Membro de USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 19
Ao todo: 789
