Introdução
If your Chromebook is not working correctly, then this guide is going to help you get your laptop working again. When working on replacing your motherboard, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that doesn't generate static electricity, like wood, tile, or other hard floors.
O que você precisa
Flip the laptop upside down with the rear end of the computer away from you.
7 outras pessoas executaram este guia.
