Introdução
The touch screen on the ASUS Chromebook C101P is great for work as a tablet or as a simple screen. Like other laptop screens, this one is equally susceptible to breaking or not responding. Replacing it is a little tricky, requiring not only the screen, but the hinge to be removed as well. It is advised to turn off the Chromebook before taking apart the screen.
O que você precisa
Flip the Chromebook so that the bottom is facing up.
Remove the nine T5 Torx screws.
Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
Separate the keyboard from the rest of the laptop.
Detach the the screen cables from the motherboard using a pair of tweezers.
Peel off the tape or seal to easily remove the screen cables.
