Introdução
The RAM of your computer acts as the computer's "working" memory. The operating system and every program, application, and process requires memory to operate. The more memory your computer has available, generally speaking, the more it can do at once. Replacing your Asus A53U-ES21's RAM with faster and larger memory can noticeably improve its performance.
O que você precisa
Remove the 5mm screw holding the RAM panel in place with a Phillips #1 screwdriver.
Uma outra pessoa concluiu este guia.
