Ir para o conteúdo principal
Asus A53U-ES21 Motherboard Replacement
O que você precisa
  1. Asus A53U-ES21 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Motherboard Replacement: passo 2, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 2, imagem 2 %32
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Motherboard Replacement, Optical Drive: passo 3, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement, Optical Drive: passo 3, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  4. Asus A53U-ES21 Motherboard Replacement: passo 4, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 4, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
  5. Asus A53U-ES21 Motherboard Replacement, Keyboard: passo 5, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement, Keyboard: passo 5, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement, Keyboard: passo 5, imagem 3 %32
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  6. Asus A53U-ES21 Motherboard Replacement: passo 6, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 6, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement: passo 6, imagem 3 %32
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  7. Asus A53U-ES21 Motherboard Replacement: passo 7, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 7, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement: passo 7, imagem 3 %32
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
  8. Asus A53U-ES21 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Close the laptop and place it upside down.
    • Remove the twelve 7mm screws using a Phillips #1 screwdriver.
  9. Asus A53U-ES21 Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the two 2mm screws using a Phillips #1 screwdriver.
  10. Asus A53U-ES21 Motherboard Replacement: passo 10, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 10, imagem 2 %32
    • Pull the connectors away from the wireless card using the plastic opening tools.
    • Pull the white connector from its socket in the RAM panel.
  11. Asus A53U-ES21 Motherboard Replacement: passo 11, imagem 1 %32
    • Flip the laptop over again, open it, and unscrew the three 7mm screws using a Phillips #1 screwdriver.
  12. Asus A53U-ES21 Motherboard Replacement: passo 12, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 12, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement: passo 12, imagem 3 %32
    • Gently pull the tan flap off of the cable using the plastic opening tool.
    • Push the tan piece towards the cable and release it using the plastic opening tool.
    • Pull the black flap off of its connector.
  13. Asus A53U-ES21 Motherboard Replacement: passo 13, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 13, imagem 2 %32
    • Separate the front plate of the laptop from the back using the plastic opening tool.
  14. Asus A53U-ES21 Motherboard Replacement: passo 14, imagem 1 %32 Asus A53U-ES21 Motherboard Replacement: passo 14, imagem 2 %32 Asus A53U-ES21 Motherboard Replacement: passo 14, imagem 3 %32
    • Remove the single 7mm screw from the motherboard using a Phillips #1 screwdriver.
    • Pull to two shown cables from their sockets using the plastic opening tools.
    • Gently remove the motherboard from the laptop.
Conclusão
Chase Poirier
Membro desde: 10/23/18
544 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G3, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Duração total: 915
