Ir para o conteúdo principal
Asus A52F RAM Replacement
O que você precisa
  1. Asus A52F RAM Replacement, Battery: passo 1, imagem 1 %32 Asus A52F RAM Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F RAM Replacement: passo 2, imagem 1 %32 Asus A52F RAM Replacement: passo 2, imagem 2 %32
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F RAM Replacement, Lower Case: passo 3, imagem 1 %32 Asus A52F RAM Replacement, Lower Case: passo 3, imagem 2 %32 Asus A52F RAM Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F RAM Replacement: passo 4, imagem 1 %32 Asus A52F RAM Replacement: passo 4, imagem 2 %32
    • Slide the back panel away and remove the panel.
  5. Asus A52F RAM Replacement, RAM: passo 5, imagem 1 %32
    • Gently push the metal retaining arms away from the center of the RAM module.
  6. Asus A52F RAM Replacement: passo 6, imagem 1 %32 Asus A52F RAM Replacement: passo 6, imagem 2 %32 Asus A52F RAM Replacement: passo 6, imagem 3 %32
    • The RAM should now be sticking up at a 30° angle.
    • Carefully grab the top edge of the RAM and gently pull it it out at it's angle.
  7. Asus A52F RAM Replacement: passo 7, imagem 1 %32
    • Repeat removal process for the RAM underneath.
  8. Asus A52F RAM Replacement: passo 8, imagem 1 %32 Asus A52F RAM Replacement: passo 8, imagem 2 %32
    • To insert new RAM line up notch in the connector and slide in at a 30° angle.
    • RAM only goes in one way!
    • Push straight down until the metal clips on both sides click into place
Conclusão
3 outras pessoas executaram este guia.
Bradley Varnum
Membro desde: 03/09/17
345 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 44
Ao todo: 1,226
