Ir para o conteúdo principal
Asus A52F Hard Drive Replacement
O que você precisa
  1. Asus A52F Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Asus A52F Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: passo 2, imagem 1 %32 Asus A52F Hard Drive Replacement: passo 2, imagem 2 %32
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: passo 3, imagem 1 %32 Asus A52F Hard Drive Replacement, Lower Case: passo 3, imagem 2 %32 Asus A52F Hard Drive Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: passo 4, imagem 1 %32 Asus A52F Hard Drive Replacement: passo 4, imagem 2 %32
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Asus A52F Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32 Asus A52F Hard Drive Replacement, Hard Drive: passo 5, imagem 3 %32
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: passo 6, imagem 1 %32 Asus A52F Hard Drive Replacement: passo 6, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: passo 7, imagem 1 %32 Asus A52F Hard Drive Replacement: passo 7, imagem 2 %32
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
Conclusão
Uma outra pessoa concluiu este guia.
Roman Justice
Membro desde: 03/08/17
225 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 1,550
