Introdução
The following guide will help the user remove the screen. The screen trim can been removed using a spudger. A Phillips #0 screwdriver is needed to remove the screws keeping the screen attached to the laptop.
O que você precisa
Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
