Ir para o conteúdo principal
Asus 1015E-DS03 Keyboard Replacement
O que você precisa
  1. Asus 1015E-DS03 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Keyboard Replacement: passo 2, imagem 1 %32
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Keyboard Replacement: passo 3, imagem 1 %32
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Keyboard Replacement: passo 4, imagem 1 %32
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Keyboard Replacement: passo 6, imagem 1 %32 Asus 1015E-DS03 Keyboard Replacement: passo 6, imagem 2 %32
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
  7. Asus 1015E-DS03 Keyboard Replacement: passo 7, imagem 1 %32
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Keyboard Replacement: passo 8, imagem 1 %32
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Keyboard Replacement: passo 9, imagem 1 %32 Asus 1015E-DS03 Keyboard Replacement: passo 9, imagem 2 %32
    • Gently pull the strip out of the square slot.
Conclusão
Joe Capriola
Membro desde: 03/21/16
428 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 7-4, Benson Spring 2016 Membro de Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 1,023
