Ir para o conteúdo principal
Astro Pyle PTBL7C Speakers Replacement
O que você precisa
  1. Astro Pyle PTBL7C Speakers Replacement, Case Separation: passo 1, imagem 1 %32 Astro Pyle PTBL7C Speakers Replacement, Case Separation: passo 1, imagem 2 %32
    • Slide the flat end of the spudger under the front edge of the screen and carefully pry it open.
    • The front edge is the side with the buttons on it.
    • You may hear a cracking sound when pulling the case off of the device. This is normal, and is just the clips being pulled apart. However, be careful and pull the clips slowly/cautiously to avoid damage.
    • Be aware of the speaker cable when removing the case, as it is still attached to the motherboard.
  2. Astro Pyle PTBL7C Speakers Replacement, Tape Removal: passo 2, imagem 1 %32
    • Locate the Speakers; they should be attached to the case as shown.
    • Follow the wires back to the motherboard, removing all tape covering the wires along the way.
    • This will make it easier to move the wires around.
    • Desolder the black wire from the motherboard. This will separate the speakers from the board, allowing you to replace them.
    • Exercise EXTREME caution while soldering. It is very easy to burn yourself, or damage the surrounding components. For a basic guide of how to desolder, follow this link: http://www.dummies.com/programming/elect...
Conclusão
Abdulelah
Membro desde: 10/22/16
214 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 5-5, Wilson Fall 2016 Membro de IUPUI, Team 5-5, Wilson Fall 2016
IUPUI-WILSON-F16S5G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 222
