Ir para o conteúdo principal
Astro A50 Headband Replacement
O que você precisa
  1. Astro A50 Headband Replacement, Headband: passo 1, imagem 1 %32 Astro A50 Headband Replacement, Headband: passo 1, imagem 2 %32
    • Remove the six screws—three from each side of the headband
    • These screws have been glued. Apply heat in order to loosen the adhesive.
  2. Astro A50 Headband Replacement: passo 2, imagem 1 %32
    • Remove the head piece from the ear pieces.
    • Separate the wire that connects the two ear pieces.
    • Replace or repair the broken head pieces.
    • A repair could be as simple as gluing the broken parts. When reinstalling to line up the adjusters correctly, make sure they function with the new parts before completely reassembling the head set.
Conclusão
3 outras pessoas executaram este guia.
Nicholas Eriksen
Membro desde: 10/28/15
987 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-5, Shastany Fall 2015 Membro de UMass Dartmouth, Team 2-5, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 76
Duração total: 17,572
