Ir para o conteúdo principal
Astro A50 2016 Headset Buttons Replacement
O que você precisa
  1. Astro A50 2016 Headset Buttons Replacement, Headset Speakers: passo 1, imagem 1 %32 Astro A50 2016 Headset Buttons Replacement, Headset Speakers: passo 1, imagem 2 %32
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Buttons Replacement: passo 2, imagem 1 %32
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Buttons Replacement: passo 3, imagem 1 %32
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Buttons Replacement: passo 4, imagem 1 %32
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Buttons Replacement, Headset Buttons: passo 5, imagem 1 %32
    • Remove the three 6mm PH1 screws.
  6. Astro A50 2016 Headset Buttons Replacement: passo 6, imagem 1 %32
    • Remove the four 6 mm PH1 screws.
  7. Astro A50 2016 Headset Buttons Replacement: passo 7, imagem 1 %32
    • Dettach the thin circuit board from the ribbon with your hand by pulling the board and wire in different directions.
  8. Astro A50 2016 Headset Buttons Replacement: passo 8, imagem 1 %32
    • Pull the two unscrewed buttons away from the ear cuffs with your hand.
  9. Astro A50 2016 Headset Buttons Replacement: passo 9, imagem 1 %32
    • Remove the two 6mm PH1 screws.
    • Pull the unscrewed button away from the ear cuffs with your hand.
  10. Astro A50 2016 Headset Buttons Replacement: passo 10, imagem 1 %32 Astro A50 2016 Headset Buttons Replacement: passo 10, imagem 2 %32
    • Use your hands to pull the volume wheel up and away from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Vincent Seguin
Membro desde: 10/02/17
379 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S15-G1, Livingston Fall 2017 Membro de Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
Membros da 3
Autoria de 10 guias
2 comentários
hola una pregunta saben donde consiguen la rueda de volumen ya que mis astro a50 de tercera generacion de xbox tiene un problema cuando le giras la rueda para subir el volumen y bajar el volumen ya que no funciona del todo bien, en pocas palabras no hace bien su funcion al regular el sonido al girar la rueda y quisiera reparar eso.
bryan200131 - Responder
Yo también tengo el mismo problema. He encontrado unas piezas similares en Ali express pero no sé si le queden a los astro a50. Son de la marca Logitech pero para los G933. La pieza se ve muy parecida. Para evitar problemas yo estoy buscando la placa de circuitos completa, pero no la he encontrado. Si sabes algo te agradecería lo compartieras
omar ramirez marin -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 2,228
