Introdução
In this guide we will take you through replacing a faulty microphone jack of your Astro A40 TR.
If you want to be able to communicate with fellow gamers but your microphone is starting to intermittently lose sound or completely stopped working, then it may be time to replace your microphone jack. A microphone jack enables sound to transmit into the computer or other device.
In order to completely replace the speaker, step 5 contains instructions on how to solder and desolder connections.
Before you begin, make sure you have the proper tools needed.
O que você precisa
To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
Remove the three screws in the photo with the J00 driver bit, and pull the headphone jack away from the assembly.
Un-solder the two wires circled, at this point the entire assembly can be removed from the speaker and the remainder of the device.
Where can i buy a replacement port/board?
Where can a replacement jack purchased
Uma outra pessoa concluiu este guia.
