Ir para o conteúdo principal
Astro A40 TR External Headband Replacement
O que você precisa
  1. Astro A40 TR External Headband Replacement, External Headband: passo 1, imagem 1 %32 Astro A40 TR External Headband Replacement, External Headband: passo 1, imagem 2 %32
    • Remove two hex screws on each side to free and remove the base plate. Do each step for both sides.
  2. Astro A40 TR External Headband Replacement: passo 2, imagem 1 %32 Astro A40 TR External Headband Replacement: passo 2, imagem 2 %32
    • Pull apart earpiece assembly and the connecting headband piece.
  3. Astro A40 TR External Headband Replacement: passo 3, imagem 1 %32 Astro A40 TR External Headband Replacement: passo 3, imagem 2 %32
    • Gently pull the padding layer off of both ends using your hands.
  4. Astro A40 TR External Headband Replacement: passo 4, imagem 1 %32 Astro A40 TR External Headband Replacement: passo 4, imagem 2 %32 Astro A40 TR External Headband Replacement: passo 4, imagem 3 %32
    • Locate the black wiring and gently pull it out of the plastic headpiece component.
Conclusão
Mike
Membro desde: 10/20/16
448 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 6-5, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
Membros da 3
Autoria de 10 guias
6 comentários
Is there any place you can purchase a new external headband? The part that holds the foam piece in place broke on mine yesterday :(
zironyy - Responder
i dont have the screws i lost them when i dropped my headset
Sniping_Ninja10 - Responder
Did you buy screws? I need as well but I don’t know which one is good!
photo -
Where Can I buy screws for? I know the size is T8 but how long? which one is good for? Please help me
photo - Responder
where can i buy a new headband
Dewis Polonia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 66
Duração total: 13,770
