Ir para o conteúdo principal
Astro A40 Gen2 Speaker Replacement
O que você precisa
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: passo 1, imagem 1 %32 Astro A40 Gen2 Speaker Replacement, Ear Pad: passo 1, imagem 2 %32
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: passo 2, imagem 1 %32 Astro A40 Gen2 Speaker Replacement, Speaker: passo 2, imagem 2 %32
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: passo 3, imagem 1 %32 Astro A40 Gen2 Speaker Replacement: passo 3, imagem 2 %32
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: passo 4, imagem 1 %32
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: passo 5, imagem 1 %32
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
Conclusão
Uma outra pessoa concluiu este guia.
Donavan Feliz
Membro desde: 01/22/15
444 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-18, Maness Winter 2015 Membro de Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
Membros da 4
Autoria de 10 guias
2 comentários
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - Responder
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 4,479
