Introdução
In this guide, we will be reaching and removing the buttons on the mixamp. This guide is helpful if you are looking to replace or fix a stuck button on your own.
O que você precisa
Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
Remove the input casing using your fingers.
Remove the four 5.8 mm Phillips #0 screws on the motherboard.
3 outras pessoas executaram este guia.
