Ir para o conteúdo principal
Astro A20 Cushion Replacement
O que você precisa
  1. Astro A20 Cushion  Replacement, Cushion: passo 1, imagem 1 %32
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20 Cushion  Replacement: passo 2, imagem 1 %32
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20 Cushion  Replacement: passo 3, imagem 1 %32 Astro A20 Cushion  Replacement: passo 3, imagem 2 %32
    • Remove the ear cushion from the headset.
Conclusão
1Comentário do guia
The lighting is quite poor. I can't see what you're doing at all.
It's also missing a lot of information. Are they glued down? Are you able to get the ear cups off intact so they can be replaced after your wash them?
Vitrified Valkyrie - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 75
Ao todo: 7,264
