Ir para o conteúdo principal
Astro A20 Battery Replacement
O que você precisa
  1. Astro A20 Battery Replacement, Cushion: passo 1, imagem 1 %32
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20 Battery Replacement: passo 2, imagem 1 %32
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20 Battery Replacement: passo 3, imagem 1 %32 Astro A20 Battery Replacement: passo 3, imagem 2 %32
    • Remove the ear cushion from the headset.
  4. Astro A20 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Place hand on the opposite side of the speaker.
  5. Astro A20 Battery Replacement: passo 5, imagem 1 %32 Astro A20 Battery Replacement: passo 5, imagem 2 %32
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20 Battery Replacement: passo 6, imagem 1 %32
    • Lift and remove the speaker from the headset.
  7. Astro A20 Battery Replacement: passo 7, imagem 1 %32
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  8. Astro A20 Battery Replacement: passo 8, imagem 1 %32
    • Lift the motherboard to expose the battery.
  9. Astro A20 Battery Replacement: passo 9, imagem 1 %32
    • Remove the battery with a plastic spudger.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 70
Últimos 30 dias: 340
Duração total: 14,322
