Ir para o conteúdo principal
Astak Mole Camera Head Replacement
O que você precisa
  1. Astak Mole Camera Head Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Camera Head Replacement: passo 2, imagem 1 %32
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Camera Head Replacement: passo 3, imagem 1 %32
    • Remove the SD card.
  4. Astak Mole Camera Head Replacement: passo 4, imagem 1 %32
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Camera Head Replacement: passo 5, imagem 1 %32
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Camera Head Replacement, Camera Head: passo 6, imagem 1 %32
    • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
    • Screw measurements: Length=7.0mm.
    • The third screw can be exposed by rotating the camera head.
    • Do not force the camera head farther than it will allow you.
  7. Astak Mole Camera Head Replacement: passo 7, imagem 1 %32
    • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
    • Screw measurements: Length=3.5mm
  8. Astak Mole Camera Head Replacement: passo 8, imagem 1 %32 Astak Mole Camera Head Replacement: passo 8, imagem 2 %32 Astak Mole Camera Head Replacement: passo 8, imagem 3 %32
    • Separate the three indicated outputs from the motherboard with metal spudger.
    • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
  9. Astak Mole Camera Head Replacement: passo 9, imagem 1 %32
    • Separate the wire from CPU by cutting adhesive with metal spudger.
    • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
    • Be careful not to damage the CPU in the process. This is not a wired connection.
Conclusão
Bryan
Membro desde: 09/15/16
104 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2016 Membro de USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 471
