Ir para o conteúdo principal
Assembling Parabolic Solar Cooker Tripod Base Stand
O que você precisa
  1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: passo 1, imagem 1 %32 Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: passo 1, imagem 2 %32
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Tripod Base Stand: passo 2, imagem 1 %32
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
Conclusão
To disassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Ashlie Reott
Membro desde: 10/20/13
340 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-30, Amido Fall 2013 Membro de Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 676
