Ir para o conteúdo principal
Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar
O que você precisa
  1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: passo 1, imagem 1 %32 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: passo 1, imagem 2 %32
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: passo 2, imagem 1 %32
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  3. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: passo 3, imagem 1 %32 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: passo 3, imagem 2 %32
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
Conclusão
To disassemble your device, follow these instructions in reverse order.
Ashlie Reott
Membro desde: 10/20/13
340 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-30, Amido Fall 2013 Membro de Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 584
