Ir para o conteúdo principal
Arturia Microbrute Opening Procedure
O que você precisa
  1. Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: passo 1, imagem 1 %32 Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: passo 1, imagem 2 %32
    • Switch off the Microbrute and make sure to disconnect any cables.
    • Don’t forget the mini patch bay on the top right.
  2. Arturia Microbrute Opening Procedure: passo 2, imagem 1 %32
    • Flip the Microbrute over and put it on a soft surface to not damage the knobs and faders.
    • Use a screwdriver to remove the twelve Philips screws on the bottom plate.
  3. Arturia Microbrute Opening Procedure: passo 3, imagem 1 %32 Arturia Microbrute Opening Procedure: passo 3, imagem 2 %32 Arturia Microbrute Opening Procedure: passo 3, imagem 3 %32
    • Put the Microbrute on its front edge and carefully tilt open the bottom plate including the keyboard.
    • Be aware of the ribbon cable connecting the keyboard to the PCB.
    • The cable should give you enough slack to put the top section over the keyboard section for better handling.
  4. Arturia Microbrute Opening Procedure: passo 4, imagem 1 %32
    • Next, focus on the connector of the keyboard.
  5. Arturia Microbrute Opening Procedure: passo 5, imagem 1 %32 Arturia Microbrute Opening Procedure: passo 5, imagem 2 %32 Arturia Microbrute Opening Procedure: passo 5, imagem 3 %32
    • Use a spudger to unlock the connector by pushing both left and right locking tabs tabs towards the cable.
  6. Arturia Microbrute Opening Procedure: passo 6, imagem 1 %32 Arturia Microbrute Opening Procedure: passo 6, imagem 2 %32
    • Grab the ribbon cable with your fingers and pull it out of the connector.
  7. Arturia Microbrute Opening Procedure: passo 7, imagem 1 %32
    • Now the Microbrute is open and the bottom plate with the keyboard is separated from the rest of the device.
Conclusão
Tobias Isakeit
Membro desde: 03/31/14
129.380 Reputação
Autoria de 189 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Ao todo: 301
