Introdução
This guide shows how to remove the heating element and/or the thermostat. The process of removing either or both parts is the same; therefore, we have combined them into one guide. First, the device will have to be opened. Please see the guide for lid replacement to start the process of opening the device.
Ferramentas
Peças
Nenhum componente especificado.
Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry this piece from the bottom to get the tab from behind the stainless steel to in front of the steel as shown.
Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
Uma outra pessoa concluiu este guia.
