Ir para o conteúdo principal
Aroma ARC-914SBD Heating Element/ Thermostat Replacement
O que você precisa
  1. Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Lid: passo 1, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Lid: passo 1, imagem 2 %32
    • Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
  2. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 2, imagem 1 %32
    • Remove the screw that was behind the condensation catcher using a Phillips head screwdriver, size PH2.
  3. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 3, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 3, imagem 2 %32
    • Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 4, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 4, imagem 2 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 4, imagem 3 %32
    • To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed.
  5. Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Heating Element/ Thermostat: passo 5, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Heating Element/ Thermostat: passo 5, imagem 2 %32
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry this piece from the bottom to get the tab from behind the stainless steel to in front of the steel as shown.
  6. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 6, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 6, imagem 2 %32
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 7, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 7, imagem 2 %32
    • Using a Phillips head screwdriver, size PH2, remove the screws from the control module to expose wired connections.
  8. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 8, imagem 1 %32
    • Unplug thermostat from control module
  9. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 9, imagem 1 %32
    • Remove red and blue wires from heating element to fully detach from control module. This is done by removing the screws on the heating element terminals using a Phillips head screwdriver, size PH2.
  10. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 10, imagem 1 %32 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: passo 10, imagem 2 %32
    • Again, using a Phillips head screwdriver, size PH2, remove the three screws holding the heating element assembly to the bowl. This will remove the heating element and the thermostat.
Conclusão
Uma outra pessoa concluiu este guia.
Brandon Nieves
Membro desde: 09/04/15
956 Reputação
8 Guias de autoria
Equipe
USF Tampa, Team 2-3, Sullivan Fall 2015 Membro de USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 Membros
8 Guias de autoria
Um comentário
Where do you get a replacement thermostat?
4forums - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 1,646
