Ir para o conteúdo principal
Arnova 7K G3 Camera Replacement
O que você precisa
  1. Arnova 7K G3 Camera Replacement, Rear Cover: passo 1, imagem 1 %32 Arnova 7K G3 Camera Replacement, Rear Cover: passo 1, imagem 2 %32 Arnova 7K G3 Camera Replacement, Rear Cover: passo 1, imagem 3 %32
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Camera Replacement: passo 2, imagem 1 %32 Arnova 7K G3 Camera Replacement: passo 2, imagem 2 %32
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Camera Replacement: passo 3, imagem 1 %32
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 4, imagem 1 %32 Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Arnova 7K G3 Camera Replacement: passo 5, imagem 1 %32 Arnova 7K G3 Camera Replacement: passo 5, imagem 2 %32 Arnova 7K G3 Camera Replacement: passo 5, imagem 3 %32
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Arnova 7K G3 Camera Replacement: passo 6, imagem 1 %32 Arnova 7K G3 Camera Replacement: passo 6, imagem 2 %32 Arnova 7K G3 Camera Replacement: passo 6, imagem 3 %32
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
  7. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Motherboard: passo 7, imagem 1 %32
    • Remove the two Phillips #00 screws from the motherboard.
  8. Arnova 7K G3 Camera Replacement: passo 8, imagem 1 %32
    • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
  9. Arnova 7K G3 Camera Replacement, Camera: passo 9, imagem 1 %32 Arnova 7K G3 Camera Replacement, Camera: passo 9, imagem 2 %32
    • Locate the camera and camera ribbon connection on the backside of the motherboard.
  10. Arnova 7K G3 Camera Replacement: passo 10, imagem 1 %32 Arnova 7K G3 Camera Replacement: passo 10, imagem 2 %32
    Comprar
    • Unlock the camera ribbon connector clip using a pair of tweezers.
  11. Arnova 7K G3 Camera Replacement: passo 11, imagem 1 %32 Arnova 7K G3 Camera Replacement: passo 11, imagem 2 %32 Arnova 7K G3 Camera Replacement: passo 11, imagem 3 %32
    • Gently by hand, remove the camera and its ribbon by pulling the camera away from the motherboard.
    • There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera.
Conclusão
Kue
Membro desde: 03/18/15
301 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-2, Lauer Spring 2015 Membro de Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 232
