Ir para o conteúdo principal
ArmorAll AA255 Motor Replacement
O que você precisa
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: passo 1, imagem 1 %32
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Motor Replacement: passo 2, imagem 1 %32
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Motor Replacement: passo 3, imagem 1 %32
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Motor Replacement: passo 4, imagem 1 %32 ArmorAll AA255 Motor Replacement: passo 4, imagem 2 %32
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Motor Replacement, Motor: passo 5, imagem 1 %32 ArmorAll AA255 Motor Replacement, Motor: passo 5, imagem 2 %32 ArmorAll AA255 Motor Replacement, Motor: passo 5, imagem 3 %32
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. ArmorAll AA255 Motor Replacement: passo 6, imagem 1 %32 ArmorAll AA255 Motor Replacement: passo 6, imagem 2 %32 ArmorAll AA255 Motor Replacement: passo 6, imagem 3 %32
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. ArmorAll AA255 Motor Replacement: passo 7, imagem 1 %32 ArmorAll AA255 Motor Replacement: passo 7, imagem 2 %32 ArmorAll AA255 Motor Replacement: passo 7, imagem 3 %32
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. ArmorAll AA255 Motor Replacement: passo 8, imagem 1 %32 ArmorAll AA255 Motor Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. ArmorAll AA255 Motor Replacement: passo 9, imagem 1 %32 ArmorAll AA255 Motor Replacement: passo 9, imagem 2 %32
    • The motor is ready for replacement. Pull the motor to separate.
Conclusão
6 outras pessoas executaram este guia.
YeaJun Yoo
Membro desde: 02/11/16
302 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Baechle Spring 2016 Membro de IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
Membros da 4
Autoria de 4 guias
4 comentários
What is the motor product no? It will help if there is a link to buy the motor
Austin K - Responder
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - Responder
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - Responder
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 55
Duração total: 3,951
