Ir para o conteúdo principal
Arlo Pro 2 Base Station Sensors Replacement
O que você precisa
  1. Arlo Pro 2 Base Station Sensors Replacement, Base Station Motherboard: passo 1, imagem 1 %32 Arlo Pro 2 Base Station Sensors Replacement, Base Station Motherboard: passo 1, imagem 2 %32 Arlo Pro 2 Base Station Sensors Replacement, Base Station Motherboard: passo 1, imagem 3 %32
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws on the side of the base station, above the USB ports.
    • Pull apart the top case from the bottom.
    • This may require some force as there are internal catches.
  2. Arlo Pro 2 Base Station Sensors Replacement: passo 2, imagem 1 %32 Arlo Pro 2 Base Station Sensors Replacement: passo 2, imagem 2 %32 Arlo Pro 2 Base Station Sensors Replacement: passo 2, imagem 3 %32
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws to disconnect the motherboard from the base casing.
    • The motherboard is connected to the USB ports; when removing it be careful to gently remove the USB ports from their cavities to avoid any damage.
  3. Arlo Pro 2 Base Station Sensors Replacement, Base Station Sensors: passo 3, imagem 1 %32 Arlo Pro 2 Base Station Sensors Replacement, Base Station Sensors: passo 3, imagem 2 %32 Arlo Pro 2 Base Station Sensors Replacement, Base Station Sensors: passo 3, imagem 3 %32
    • Follow the black wire running from each thin metal sensor to the motherboard; they will be connected under a piece of black tape.
    • Pull back the black tape to see where the wire you are following attaches to the motherboard.
    • Pull up on the coaxial connector to disconnect the wire from the motherboard.
  4. Arlo Pro 2 Base Station Sensors Replacement: passo 4, imagem 1 %32 Arlo Pro 2 Base Station Sensors Replacement: passo 4, imagem 2 %32 Arlo Pro 2 Base Station Sensors Replacement: passo 4, imagem 3 %32
    • Snake the wires through any place where it goes through the plastic casing.
    • Gently pull the metal sensor away from the plastic casing to fully disconnect it from the motherboard.
Conclusão
Ben I.
Membro desde: 03/26/25
493 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 104
