Ir para o conteúdo principal
Archos Jukebox Recorder 20 Motherboard Replacement
O que você precisa
  1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: passo 3, imagem 1 %32
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Motherboard Replacement: passo 4, imagem 1 %32
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Motherboard Replacement: passo 5, imagem 1 %32 Archos Jukebox Recorder 20 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the face.
  6. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove four surrounding T5 screws as shown
  7. Archos Jukebox Recorder 20 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
  8. Archos Jukebox Recorder 20 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
  9. Archos Jukebox Recorder 20 Motherboard Replacement: passo 9, imagem 1 %32 Archos Jukebox Recorder 20 Motherboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
  10. Archos Jukebox Recorder 20 Motherboard Replacement: passo 10, imagem 1 %32 Archos Jukebox Recorder 20 Motherboard Replacement: passo 10, imagem 2 %32
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Conclusão
Shaun Rifield
Membro desde: 03/21/18
121 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G3, Freund Spring 2018 Membro de IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 406
