Ir para o conteúdo principal
Archos Jukebox Recorder 20 Hard Drive Replacement
O que você precisa
  1. Archos Jukebox Recorder 20 Hard Drive  Replacement, Battery: passo 1, imagem 1 %32
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 2, imagem 1 %32
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: passo 3, imagem 1 %32 Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: passo 3, imagem 2 %32
    • Use the T10 Torx Screwdriver to remove the 2 torx screws on each side of the device.
    • Two on each side for a total of four.
  4. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 4, imagem 1 %32 Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 4, imagem 2 %32
    • Remove the 2 screws on the top and the 2 screws on the bottom of the device using a Phillips #0 screwdriver.
  5. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 5, imagem 1 %32
    • Remove the outer metal casing of the device by popping it off with a plastic opening tool.
  6. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 6, imagem 1 %32
    • Remove the rubber bumpers on all four corners of the device.
  7. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 7, imagem 1 %32 Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 7, imagem 2 %32
    • Lift the hard drive out of its casing with the help of a plastic opening tool and slide it out. This will disconnect the pins connecting the drive to the rest of the device.
Conclusão
Aidan Patterson
Membro desde: 01/08/18
354 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G4, Freund Spring 2018 Membro de IUPUI, Team S1-G4, Freund Spring 2018
IUPUI-FREUND-S18S1G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 30
Duração total: 1,326
