Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
If you want to replace the screen on your tablet, then this guide is for you. Use this step by step guide on how to properly replace the display screen on your Archos 97 Carbon tablet.
Peças
Nenhum componente especificado.
  1. Lay your tablet upwards facing you. Using the opening tool, being prying the tablet starting in the top left corner near the volume and power button. Then work your way around in a clockwise motion to separate the screen from the back cover.
    • Lay your tablet upwards facing you.
    • Using the opening tool, being prying the tablet starting in the top left corner near the volume and power button. Then work your way around in a clockwise motion to separate the screen from the back cover.
  2. Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet. Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab. Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
    • Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
    • Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
  3. On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard. Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • The screen should be separated from the tablet.
  4. Remove the screws on the backside of the screen using a screwdriver. There are four screws; one is covered by tape.
    • Remove the screws on the backside of the screen using a screwdriver.
    • There are four screws; one is covered by tape.
  5. Gently pry the screen from the black frame that surrounds it using the opening tool. Work in a clockwise motion until the screen is detached from the frame. Work in a clockwise motion until the screen is detached from the frame.
    • Gently pry the screen from the black frame that surrounds it using the opening tool.
    • Work in a clockwise motion until the screen is detached from the frame.
Conclusão
2 outras pessoas concluíram este guia.
Allyson Seber
Membro desde: 03/03/2015
311 Reputação
2 Guias de autoria
Hi,
Is this similar to replacing the touch screen on the Archos 101B model?.
colin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,331
