Ir para o conteúdo principal
Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement
O que você precisa
  1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: passo 1, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: passo 1, imagem 2 %32
    • Turn off the water supply by turning the water valve(s) to be horizontal, or perpendicular to the water pipe.
    • You may have one or two valves depending on the installation of your system.
  2. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 2, imagem 1 %32
    • Press the black pressure release button on top of the filter housing.
    • Hold the button down for 5 seconds.
  3. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 3, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 3, imagem 2 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 3, imagem 3 %32
    • Unscrew the filter housing canister clockwise with a water filter housing wrench.
  4. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 4, imagem 1 %32
    • Remove the dirty pre-filter and dispose of it.
  5. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 5, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 5, imagem 2 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 5, imagem 3 %32
    • Wash the filter housing canister with dish soap and water.
    • You may need a long-handled cleaning brush to scrub off dirt and debris.
    • Rinse and dry the filter housing canister.
  6. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 6, imagem 1 %32
    • Remove the O-ring from the housing canister.
  7. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 7, imagem 1 %32
    • Clean off old grease on the O-ring with a towel.
  8. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 8, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 8, imagem 2 %32
    • Replace the O-ring.
    • Apply Vaseline or lube around the seal.
  9. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 9, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 9, imagem 2 %32
    • Place the new pre-filter in the center of the filter housing canister.
  10. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 10, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 10, imagem 2 %32
    • Screw the filter housing canister counter-clockwise with your hands.
  11. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 11, imagem 1 %32
    • Tighten the filter housing canister with the filter wrench.
  12. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 12, imagem 1 %32 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 12, imagem 2 %32
    • Turn on the water supply by turning the water valve(s) to be vertical, or parallel to the water pipe.
  13. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: passo 13, imagem 1 %32
    • Run water in a sink or tub for 1-2 minutes to flush out the system and remove any air in the pipes.
Conclusão
Repeat steps every 2-3 months for best results.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 235
