Ir para o conteúdo principal
Aquarium Top Filter Box Replacement
O que você precisa
  1. Aquarium Top Filter Box Replacement, Aquarium Filter Box: passo 1, imagem 1 %32 Aquarium Top Filter Box Replacement, Aquarium Filter Box: passo 1, imagem 2 %32
    • Using a black sharpie marker, mark the box for accurate holes.
    • Make sure the hole is a little bit smaller than the soft PVC pipe.
  2. Aquarium Top Filter Box Replacement: passo 2, imagem 1 %32 Aquarium Top Filter Box Replacement: passo 2, imagem 2 %32
    • Use the utility knife to cut a hole in the marked position to attach the pipe.
    • Be very careful as the box is difficult to cut.
  3. Aquarium Top Filter Box Replacement: passo 3, imagem 1 %32 Aquarium Top Filter Box Replacement: passo 3, imagem 2 %32
    • Using the same utility knife, make a hole in the bottom of the plastic box for the water to come out.
  4. Aquarium Top Filter Box Replacement: passo 4, imagem 1 %32
    • Attach the soft PVC pipe with the aquarium powerhead.
    • Make sure it is properly connected.
  5. Aquarium Top Filter Box Replacement: passo 5, imagem 1 %32 Aquarium Top Filter Box Replacement: passo 5, imagem 2 %32
    • Insert the soft PVC pipe in the plastic box.
  6. Aquarium Top Filter Box Replacement: passo 6, imagem 1 %32 Aquarium Top Filter Box Replacement: passo 6, imagem 2 %32 Aquarium Top Filter Box Replacement: passo 6, imagem 3 %32
    • With a telfon tape properly wrap the soft PVC pipe for no leakage of water.
  7. Aquarium Top Filter Box Replacement: passo 7, imagem 1 %32 Aquarium Top Filter Box Replacement: passo 7, imagem 2 %32 Aquarium Top Filter Box Replacement: passo 7, imagem 3 %32
    • Use aquarium-safe silicone glue to seal the soft PVC pipe with the plastic box.
    • Make sure to let the silicone glue dry for 30 minutes.
  8. Aquarium Top Filter Box Replacement: passo 8, imagem 1 %32 Aquarium Top Filter Box Replacement: passo 8, imagem 2 %32 Aquarium Top Filter Box Replacement: passo 8, imagem 3 %32
    • Add your desired filter media best suited for your aquarium.
Conclusão
Uma outra pessoa concluiu este guia.
Seaaf
Membro desde: 05/12/21
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 37
Duração total: 700
