Ir para o conteúdo principal
Aquaris M5 back Cover Replacement
O que você precisa
  1. Aquaris M5 back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Aquaris M5 back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 back Cover Replacement: passo 2, imagem 1 %32 Aquaris M5 back Cover Replacement: passo 2, imagem 2 %32
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 back Cover Replacement: passo 3, imagem 1 %32 Aquaris M5 back Cover Replacement: passo 3, imagem 2 %32 Aquaris M5 back Cover Replacement: passo 3, imagem 3 %32
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
Conclusão
Theo Mat
Membro desde: 11/12/17
12.782 Reputação
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 841
