Introdução
Use this guide to replace the earpiece speaker in your bq Aquaris M5.
O que você precisa
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
Use an opening tool or your finger nail to open the FPC connector.
Disconnect the FPC connector cable.
Use the tip of a spudger to leverage the camera out of its housing.
Remove the front camera.
Use a SIM card eject tool, to eject the two SIM card slots on one side.
Use a SIM card eject tool, to eject the micro SD card slot on the other side.
3 outras pessoas executaram este guia.
