Ir para o conteúdo principal
Apple iSight Webcam Privacy Lens Replacement
O que você precisa
  1. Apple iSight Webcam Privacy Lens Replacement, External Body Frame: passo 1, imagem 1 %32
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Privacy Lens Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Privacy Lens Replacement: passo 3, imagem 1 %32 Apple iSight Webcam Privacy Lens Replacement: passo 3, imagem 2 %32
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Privacy Lens Replacement, Privacy Lens: passo 4, imagem 1 %32
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Privacy Lens Replacement: passo 5, imagem 1 %32 Apple iSight Webcam Privacy Lens Replacement: passo 5, imagem 2 %32
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Privacy Lens Replacement: passo 6, imagem 1 %32
    Comprar
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Privacy Lens Replacement: passo 7, imagem 1 %32
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Privacy Lens Replacement: passo 8, imagem 1 %32
    • Unscrew 2 (4.41 mm) screws seen in the picture that surround the attachment of the lens to the main body.
  9. Apple iSight Webcam Privacy Lens Replacement: passo 9, imagem 1 %32 Apple iSight Webcam Privacy Lens Replacement: passo 9, imagem 2 %32
    • ,Pull the loose circuit strip from its connection using tweezers.
    • Do this for the side connection as well. This enables the entire camera lens section to come off.
    • Pull the camera lens section off the main body.
  10. Apple iSight Webcam Privacy Lens Replacement: passo 10, imagem 1 %32 Apple iSight Webcam Privacy Lens Replacement: passo 10, imagem 2 %32
    • Unscrew the final (4.41 mm) screw that connects the lens circuitry to the aperture.
    • Then pull off the circuitry top section.
  11. Apple iSight Webcam Privacy Lens Replacement: passo 11, imagem 1 %32 Apple iSight Webcam Privacy Lens Replacement: passo 11, imagem 2 %32
    • Pull off the top piece of the lens aperture.
    • Finally, remove the privacy lens using tweezers.
Conclusão
4 outras pessoas executaram este guia.
Cullen Shorey
Membro desde: 03/21/18
274 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S5-G1, Baechle Spring 2018 Membro de IUPUI, Team S5-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,206
