Introdução
You will be separating the camera module from the rest of the device. This include removing 3 pin tabs/ribbons from the circuit board. You will have to do this carefully as any damage done to the pins will be hard to repair. The rest is just unscrewing screws.
O que você precisa
Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
4 outras pessoas executaram este guia.
