Ir para o conteúdo principal
Apple iPod Hi-Fi Power Supply Replacement
O que você precisa
  1. Apple iPod Hi-Fi Power Supply Replacement, Grille: passo 1, imagem 1 %32
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Power Supply Replacement: passo 2, imagem 1 %32
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
    Antes de poner de vuelta la placa de aluminio con el mismo secador de aire caliente puedes calentar los restos de pegamento adherido y lo montas . Pones la rejilla de tela en su lugar y lo dejas una hora apoyado con la parte trasera mirando hacia arriba.asi el pegamento recalentado y con la presión del peso del aparato hará que se adhiera.
    Olga Ona - Responder
  3. Apple iPod Hi-Fi Power Supply Replacement: passo 3, imagem 1 %32
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
  4. Apple iPod Hi-Fi Power Supply Replacement, Front Panel and Speaker Connections: passo 4, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement, Front Panel and Speaker Connections: passo 4, imagem 2 %32
    • Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
    • Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
  5. Apple iPod Hi-Fi Power Supply Replacement: passo 5, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 5, imagem 2 %32
    • Pry out the large speaker with a metal spudger around the edge.
    • Remove the speaker slowly from its socket with your hands.
    • Turning the speaker on its side will make this step much easier.
    • The speaker is still attached by several connections at this point so the speaker will not be able to be removed completely at this step.
  6. Apple iPod Hi-Fi Power Supply Replacement: passo 6, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 6, imagem 2 %32
    • Press down on the tab and pull out with your hands to remove the cable connecting the large speaker from the rest of the unit.
    • Pull the large speaker completely out and set aside.
  7. Apple iPod Hi-Fi Power Supply Replacement: passo 7, imagem 1 %32
    • Remove the sensor connection by pulling it straight out with your hand.
  8. Apple iPod Hi-Fi Power Supply Replacement: passo 8, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 8, imagem 2 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 8, imagem 3 %32
    • Pull the entire front assembly off by prying it up with the spudger and lifting the assembly off with your hands towards the top of the Hi-Fi.
    • There are still connections attached at this stage so the front assembly will not completely disconnect from the rest of the device .
  9. Apple iPod Hi-Fi Power Supply Replacement: passo 9, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 9, imagem 2 %32
    • Remove the clips for the remaining two speakers by repeating step 6.
    • Remove the last connection that connects the speakers to the power box.
    • Remove the front panel completely.
    • When reassembling, the ports are labeled "right" and "left" to help you plug in the right speaker to the right port.
  10. Apple iPod Hi-Fi Power Supply Replacement, iPod Dock Inserts: passo 10, imagem 1 %32
    • Place the speaker on its back with the dock facing away from you.
  11. Apple iPod Hi-Fi Power Supply Replacement: passo 11, imagem 1 %32
    • Remove the cable connected to the dock insert by pulling the cable straight out.
  12. Apple iPod Hi-Fi Power Supply Replacement: passo 12, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 12, imagem 2 %32
    • Remove the gold tape attaching the insert to the unit.
    • Remove the three 2mm Phillips #1 screws holding the dock inserts in by placing the screwdriver in the head of the screw and rotating counterclockwise.
  13. Apple iPod Hi-Fi Power Supply Replacement: passo 13, imagem 1 %32
    • Remove the dock insert with your hands.
  14. Apple iPod Hi-Fi Power Supply Replacement, Power Supply: passo 14, imagem 1 %32
    • Unplug the 2 cables on the top of the power supply box.
    • Unclip the cables clipped together to the left of the power supply box.
  15. Apple iPod Hi-Fi Power Supply Replacement: passo 15, imagem 1 %32
    • Remove the middle foam panel from the wall of the device closest to you by pulling the foam out with your hand.
  16. Apple iPod Hi-Fi Power Supply Replacement: passo 16, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 16, imagem 2 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 16, imagem 3 %32
    • Remove two 2mm Phillips #1 screws from the back power port by placing the screwdriver in the head of the screw and rotating counterclockwise.
    • Pull the power port straight out of its socket with your hands. The power port should come right out.
  17. Apple iPod Hi-Fi Power Supply Replacement: passo 17, imagem 1 %32 Apple iPod Hi-Fi Power Supply Replacement: passo 17, imagem 2 %32
    • Remove four 2mm Phillips #1 screws from the base of the power supply box by placing the screwdriver in the head of the screw and rotating counterclockwise.
  18. Apple iPod Hi-Fi Power Supply Replacement: passo 18, imagem 1 %32
    • Remove the power supply box with your hands.
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S16-G1, Livingston Spring 2018 Membro de Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
Membros da 5
Autoria de 15 guias
6 comentários
It not just the power supply. The amplifier board is attached to the top.
Tom Karches - Responder
Where can we find a compatible power suply? Thank you.
Victor Rizescu - Responder
Bonjour le tutoriel est très bien mais ou peut-on acheter le bloc d’alimentation ?
Merci
castan.vincent - Responder
where can i find a power supply please .
chris snook - Responder
What is the Part Number of the Apple iPod Hi-Fi internal Power Supply and Amplifier Assembly?
Roosevelt Adrianza - Responder
liteon PA-3150-01A 30w DC
BUSINESS -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 140
Duração total: 7,800
