Ir para o conteúdo principal
Apple iPod Hi-Fi Grille Replacement
O que você precisa
  1. Apple iPod Hi-Fi Grille Replacement, Grille: passo 1, imagem 1 %32
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: passo 2, imagem 1 %32
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: passo 3, imagem 1 %32
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S16-G1, Livingston Spring 2018 Membro de Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,474
