Introdução
This guide details how to replace the front panel and speaker connections of the Apple iPod Hi-Fi speaker system.
While following this guide, be sure to be careful of the protective wrapping around the interior components because the wrapping is made of small fibers that can make a large mess.
O que você precisa
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
Antes de poner de vuelta la placa de aluminio con el mismo secador de aire caliente puedes calentar los restos de pegamento adherido y lo montas . Pones la rejilla de tela en su lugar y lo dejas una hora apoyado con la parte trasera mirando hacia arriba.asi el pegamento recalentado y con la presión del peso del aparato hará que se adhiera.
Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
7 outras pessoas executaram este guia.
4 comentários
Hi, I would like to know where to purchase replacement speakers for the Apple HiFi. TIA
Hi whehe can i find a replacement bass speaker ??
Yo necesito la fuente de poder de ese equipo, por favor si alguien lo tiene me escribe a: rolando.chungag@gmail.com
